I have a 2024 Pontoon I bought brand new. Built out with all of the bells and whistles. Somewhere around 50 k - but I was excited to have a new Bennington. I have grown up in Florida on the water and was looking forward to the dependability that comes with buying new. For two years the steering worked fine. But about 6 months ago the steering has become a major safety issue. When I am running at 3/4 to full throttle the steering becomes a mess. I have to keep a hard two handed grip on the wheel or it will do a quick ( immediate) u-turn to the right. To try and turn left it sticks and I have to use quite a bit force to turn. I have been in touch with Bennington and they sent the dealership all new steering cables. This was replaced but the issue is still there. The dealership agrees that it is a safety issue, ( they went out on the sea trial after the parts were replaced) but, they say the problem is the helm not being a " no feedback " helm and I need to order an 3-4k upgrade to fix this. It did not start doing this until I took it in and got its annual service. The dealership says it is because they lubricated it. I do not understand how when getting prior service this did not come up. I have driven a lot of boats ( have owned Benningtons for 15 years) and have never experienced this. This is the email this morning from Bennington.
Morning Phyllis,
Apologies on the delayed response.
Following a detailed review with Blue Water Marine, we have completed the assessment of your warranty inquiry. A cross-reference of the replacement parts confirms that your boat was originally built with a standard cable pre-rig steering system. To address your warranty concerns, a replacement helm and steering cable matching your original specifications have been shipped to Blue Water Marine to be installed under warranty.
While you are welcome to upgrade to a non-feedback helm or a hydraulic system, Bennington cannot cover the cost of these upgrades under warranty. Because these components deviate from your boat's original factory configuration, any modifications will be at your expense. Please note that installing parts that deviate from the original build will void the warranty for that specific system, as well as any related components affected by the modification.
We place full confidence in the expertise and experience of the Blue Water Marine team to successfully resolve these issues. Please keep in mind that performing routine maintenance can often clear out residual corrosion, which may have been the underlying cause of the steering stiffness.
Thank you for your patience and understanding while we reviewed this matter.
Does anyone have any experience with this? Any ideas?
Morning Phyllis,
