They wire it that way to not have a dead battery from a boat that sits for a long period of time. (I understand that but thought that's what the Perko switch was for? They should of at least wired it to the Perko switch so when the dash power switch is cut your radio retains memory. If your going to long term store then you shut the Perko and deal with the settings later on. It wouldn't be so bad if they installed an amp that had manual audio equalization, but they don't, all settings must be adjusted through the radio head unit. I could care less about pre-set radio stations, it's the audio settings that take time to do over every time you start the boat)... I wasn't trying to be a smartass and finding the wires and doing it correctly (OK, at least we agree that it is not being wired correctly and that is why you corrected yours) much easier than hooking up a battery that isn't meant to be there. (Agreed) Chill. Our 07' was the same way and I just moved the memory wire. (where did you move it to?? Did you do it per gnc1017 recommendation above??...or did you run a wire direct to the battery??...if so did you wire before or after the Perko switch)
Thanks for the reply!
Dan
