BigBadJohnnyB
- Messages
- 7
- Reaction score
- 0
I'm having trouble visualizing.... where did you run your battery wires? Do you run them forward and around to the left, then back to the battery compartment? Or is there a shortcut that I'm not thinking of? Seems the shortcut would require going under the platform, or some of it left exposed.... obviously not desirable.I stayed with a sony Marine bluetooth receiver, WetSounds AS-10 sub under the helm with a built in 500 watt mono amp, WetSounds 8" speakers to replace the factory Sony 6 1/2" speakers in the same locations, just had to cut the opening bigger and a Focal 1500 watt amp for the 8" speakers. I ran 2 gauge welding cable from the battery location in back to under the helm where I located the amp .and the sub box. I did all the work myself and after tuning the amps, the sound is amazing.
