May 23, 2022 #1 M Mark Smith Member Messages 7 Reaction score 1 Over the years our table pedestal base has come loose and the screw holes have stripped out of the deck, Any ideas on best way to repair? Thanks
May 23, 2022 #2 Timdelta Well-Known Member Messages 473 Reaction score 621 I would use wood toothpicks and some waterproof glue/epoxy. Jam a few picks in, cut off at surface, couple drops of glue/epoxy. Screw base back on, let dry/setup. Done.
May 23, 2022 #4 S Seadoorxpguy Well-Known Member Messages 199 Reaction score 253 Wood glue or epoxy a golf tee in the hole
May 24, 2022 #5 SEMPERFI8387 Moderator Messages 14,112 Reaction score 7,802 Location York, Pa Remove the screws, rotate base slightly, reinstall screws into good section of plywood OR replace with stainless bolts/nylock nuts and washers.
