lakeliving
Mine is off to the side and interfered with the bunk. Since my boards are a little long on the sides I shortened that one and rewrapped the carpet. No issues now.
I installed a Humminbird Helix 7. I immediately bought the ChartSelect map of Bull Shoals Lake from them for $30, which has tons of features and bathymetry data down to 1' intervals on the contour lines. I mounted the transducer on the port tube, which had a rectangular "box" welded to the rear bottom of the toon (it came that way). The system works pretty flawlessly, once you get the sensitivity settings dialed in, but then my top speed is only 30. The Yamaha has a RH screw, so it follows that you mount the puck on the left-side toon, and Bennington made that easy for me.
where did you get the bracket to mount the head unit![]()
