CherokeeBoater
- Messages
- 13
- Reaction score
- 17
2017 R23 or 23RCW (tritoon) with Garmin Echo 101. I want to replace with Garmin 93SV which has a different transponder and cable, so need to get it from the help to the port transom. I’ve read all the threads here I could find, and I am still stymied. Need some advice.
My tools include two electrician’s fish tapes (one flat so only bends one way, the other round but stiffer), various sizes of rope/line (using 1/4 in as that matches the cable thickness and should pull without breaking. Usual homeowners pliers, etc. I can get some fiberglass rods like for dryer vent cleanout or chimney sweeping if needed; some have suggested those work better than a fish tape.
My plan was to first insert a line through the helm into the gap between the hulls and deck, then across to port and catch it there. I’d pull about 15 feet extra and hold the end outside of the boat on the port side, tie off the end in the helm. Then from the stern send a fish tape with a hook to “catch” the line, and pull it to stern. That should result in a line from the stern to the helm. Then attach the Garmin transponder cable (end needs 7/8 inch diameter!) at the stern, and pull it to the helm. The Garmin cable is prepped with an extension which is screwed together and taped tightly so it won’t pull apart or get wet.
In the helm there is a bunch of wires going down into the hull just starboard of the wheel. There is a boot on the floor with a zip tie to keep it. I removed the tie and tried fishing a thin line through the boot, but couldn’t get it to turn and go across to port. Others have suggested pulling it across the hull and then hooking it from above, but I don‘t have any access on the starboard side. From port side, I can see across and there are fore-aft aluminum pieces that are no doubt catching my push/pull (electrician’s) tape. I might be able to push it across from port to starboard, but then I’m stuck again trying to hook it from above - and I can’t get it through the starboard side even enough to grab it with needle nose pliers.
Looking from the stern, the cable goes in through a small access hole above the log. I tried to push my fish tape in there and again didn’t get far before hitting obstructions (4-6 ft). I might be able to use rods instead of tape for that part but it will be tight, and I’m not sure I can catch the line.
I’m about to McGyver this thing. One idea is to try to run along the starboard furniture (outboard) and then across through the fuel tank access into the battery box and then down. Might not be pretty but I think I can keep the cable protected from damage.
Does anybody have advice or ideas?
