txflash
I have a 24' SF 2012 I have a 70lb or 75lb thrust, seems to pull me around just fine.
The next question you need to ask is do you have room for two batteries, you can go up to 55lb thrust with 12 volts anything higher and you will need 24 volts.
I was told by numerous people to go with the 24 volt, or anything over the 55lb thrust
My two batteries are under the console seat or just in front of the console itself.
Hope this helps if not ask more questions, More than happy to help.
I am looking to installing a trolling motor on my 20 ft Bennington Pontoon and asking how much thrust do I need in the motor?
Thanks
Tx Flash
