RedViperinMD
- Messages
- 2
- Reaction score
- 0
About how much water does a 2275 RLCP draw? ESP tri-toon package and motor up (200 HP outboard). I have looked all over the place and I can't find the answer.
Hello RedViper. If you go up to the top right search box and type in draft, you should see 4 or 5 times this has been discussed. On March 3, 2011 TB gave some general ideas on water depth when Butchkid asked about his 2575 QCW I/O. Gerry P.S. Even with water under you, I try and stay out of too shallow water, you never know what your motor can suck up.About how much water does a 2275 RLCP draw? ESP tri-toon package and motor up (200 HP outboard). I have looked all over the place and I can't find the answer.
Thanks to all. I don't know why I hadn't found those other threads, but the TB post in the "How Shallow" thread did the trick!Hello RedViper. If you go up to the top right search box and type in draft, you should see 4 or 5 times this has been discussed. On March 3, 2011 TB gave some general ideas on water depth when Butchkid asked about his 2575 QCW I/O. Gerry P.S. Even with water under you, I try and stay out of too shallow water, you never know what your motor can suck up.
I have a Garmin Fishfinder 90/140. It doesn't have the keel offset feature.What depth finder do you have? All the ones I have seen or used have a keel offset. I have mine set at plus 1 foot. Most all garmin, humminbird, Lawrence, bottom line etc, have this feature in the set up menu.
Todd
