Winter prep on 4 stroke Mec 115
All the debate over running your system dry, I'll throw in my opinion as well, if your engine has carburetors, running it dry is ok, but i don't like the powdery residue left behind. If your engine is fuel injected, i think you should leave fuel in the system. A high pressure fuel pump depends on fuel flow to keep it cool, much like your water pump impeller, it only takes a few seconds of dry run to do damage. Plus, the fuel injectors have very small openings to create the atomized fuel spray required for proper performance, a particle of residue that would pass through a carburetor may clog a fuel injector. As for the ethanol, modern fuel systems are designed to handle up to 10% ethanol, personally i don't like ethanol at all, but it's been forced upon us. That's my 2cents, and everyone needs to make their own decision about how they treat their boat ;)
I've seen nothing from Merc suggesting running an EFI motor dry.
Good comments, Geoff.
