kaydano
- Messages
- 4,287
- Reaction score
- 2,164
I'm winterizing my motor tomorrow (Sat). Fuel injected, no carb.
Procedure is you run new gas in the tank with Stabil through the engine, then change oil/filter/lube, then remove plugs and spray fogging oil into the cylinders.
Then you run the motor a little (with plugs still out) to distribute the fogging oil around inside the cylinder.
My question is, isn't gas being injected into the cylinder at this time too? The motor thinks it's trying to start, so gas should be injected into the cylinder. But, the motor won't start since the plugs are out. Won't gas mix with the fogging oil???
The obvious answer is run the motor out of gas, but the manual doesn't say to do this.
Confused...
Maybe the gas injected is minimal, and won't hurt anything being mixed with the fogging oil...
Anyone know?
Confused...
Anyone know?
