This picture shows the mounted HDS-7 unit. All cables are tucked behind the front stbd corner box. I ran dedicated power from the console along with the ethernet cable from the Structure Scan module (mounted under the console) under the floor and up through the stbd corner box boot where the battery cables run and then drilled a small hole in the upper forward part of the corner box to exit the cables and connect to the locator. With the adapter cable from the Trolling Motor, I can view the front transducer with trolling motor deployed, or view the aft transducers including the Structure Scan.
