10 Amp Ignition Fuse That Powers Gauges On A 2275 GCW Location?
Tooncrazy
Tellico Lake, TN
Thread title covers the question.
I think many different Benningtons have the same 10 amp fuse setup so please don't hesitate to let me know where your fuse is located.
Thanks for any assistance.
Check all the fuses under the engine cowl.
I found the 10 amp blade fuse coming about 24" off the (-) side of the ignition switch. It's in a small little black box on it's own attached to a wire. Remove the top of the box to get access to the fuse.
You have to crawl way in to the far side of the helm and under the throttle control to get to it. A flash light helps. Not fun to get to. Removing the ignition switch panel does not give you access to the fuse. As far as I can tell this fuse only supplies power to the gauges.
Hope this info helps others with the same problem.
