Thanks Dan. I have also heard similar performance numbers.I have a Q27 custom with twin 300 joystick Verados currently on order. It is just about complete and should be shipping any day. While I can’t give you any first hand performance reports yet, based off everything I have seen and read, I am expecting 59-60 mph at WOT. Handling should be superb!
Good Luck on your purchase!
Dan
Thanks you for all your insight. Very helpful. I will take notice of a few of these issues when I look closer at the boat.While our new boat is a wide beam, 2024 QSBWA X2, and not the standard beam it is a twin engine boat. The boat before this one was a 2021 28 QXSBA with a single Yamaha 350. The ride was much smoother than our 2015 25 QCWA I/O. Night and day difference. What I didn't like about the 28QX with the outboard was during water sports I would easily loose any bite on the water, there was more prop cavitation.
Now comparing the 28QX with our 30Q with twins, during water sports yes there is still some prop cavitation felt in turns but not as bad. Acceleration you will feel. And if people aren't sitting when you hit the throttle, they will not be standing when you do. Another big difference we noticed with our new Q being a wide beam is how stable the boat feels in waves.
With the the twins once you learn the dual throttles some maneuvering is quite simple, we also have the Helm Master, and the joystick is the reason the wife wanted this boat, makes things dead simple even with heavier winds. Using stay point and watching the motors is something else to watch. We've actually had people think something was wrong with out boat. And being able to crab walk to the dock without a bow thruster.
The 28QX, the fastest I was able to get that to run was 45 mph. The 30Q has twin 300's and I seem to top out at 49 mph. Not sure what motors you are going with, but if they were the Yahama 300's I would expect your new boat to be able to at least hit the low to mid 50's since you have less weight to push than us. Handling of the 28QX was fine other than stated above. It was much the same as our 2015 standard beam. Our wide beam, my wife can actually reach out and touch the water when making a sharp bank, like our old ski boat back in the day.
Over all I think you will enjoy the twins for the performance and agility.
Things I have found when I was looking at the twins and have experienced since taking delivery of our late September. There are hatches in the stern of the pontoons in front of the motor, ensure they are properly inserted and latched. If your boat is going to be in a slip, have the bilge pumps in those pontoons hardwired to the battery. We trailer our boat, but still use slips from time to time, vacations and long weekend trips, so had those bilges hard wired to the house battery. Depth finder, you will loose depth readings quickly, ours with the wide beam and the elliptical toons we loose it between 9 and 10 mph as the depth finder comes out of the water. The standard beam looks to put the depth finder in about the same location. Same as the 28QX, the push button switches are quite bright and can impact your night vision at night, I use a towel to cover them at night. I'm going to look into a way to see if I can make them dimable this spring. I've also noticed sharp edges with the wave shields by the motors, you will more than likely want to ease those edges with some sanding.
If I was to stay with a standard beam and a single motor I would surely order another I/O because of the water sports, but with the twins option, just the easy of manuvability I would have a hard time deciding.
The current boarding ladder is a standard pivot ladder with a curve in it. It doesn't seem to go as deep as the two other boats that had the telescoping ladders. It is easier on the feet though. But it's not a Lillypad ladder. I am considering the Revo ladder for latter down the road, it would also give me more options for the depth finder it looks like.Thanks you for all your insight. Very helpful. I will take notice of a few of these issues when I look closer at the boat.
How do you like your current boarding ladder compared to your single engine boat? Did you have the telescoping chrome ladder?
Also, does your current boat have auto on the bilge pumps? You mentioned hardwired? Do your outer toons with the hatches fill up with water? I have a 425 now and it’s a sealed center toon with the same access door. Water is always getting into the toon and needs to be pumped out.
Yes there is a plastic 90 degree fitting that come up out of that area just forward of the hatch pointing towards the stern.Thanks again for the info.
Regarding the bilge pumps, are you saying the water is discharged to run back over top the hatch door? Mine is pumped outside the tube directly overboard. I guess no big deal as mine is stored on a lift and the auto should keep the level down.
Looking forward to seeing this boat in person next week. Several nuances that I want to understand better. Your information has been helpful.
