Battery Draining Quickly
JeffA
I'm having battery draining issues on my 2019 S20. There is an ACC light switch that's a triswitch but one of the lights is faded, so I didn't know it was on all the time. The battery drained, and I've been charging it, but I think it is on its way out. Anyone have any luck installing their own battery or adding a main power switch?
Lay Lake
Alabama
You could add a battery disconnect switch near the battery. You can then turn the battery switch to on or off. If you have dual batteries you can select 1, 2, 1+2, or off. They are pretty easy to install. Here is a link to one https://www.amazon.com/dp/B000MMC914/ref=twister_B01E512O2Q?_encoding=UTF8&th=1
I actually added a battery and installed the battery disconnect switch. Took about an hour to install a battery box, the battery and the disconnect. Having 2 batteries gives great peace of mind.
