sunedog
- Messages
- 559
- Reaction score
- 1,054
For the last few weeks, I have been having problems with battery number 2 on my 2017 RSB. It would apparently charge, but didn't seem to hold a charge. Yesterday when I put the battery selector switch on battery 2 and turned the key, nothing happened. The motor didn't crank and the gauges didn't budge. I thought that battery must be completely discharged and surely needed replaced. I moved the switch to battery 1 and the boat started and ran fine and we used it for several hours.
So today I opened the swingback to figure out which battery was number 2 and measure the voltage on both batteries. I was surprised to see one battery showed 12.88 volts and the other 12.68 volts. So the problem wasn't the battery.
I opened the compartment that housed the battery selector switch and all the wires were tight and there was no visible corrosion. But I could't see where the positive wires from battery 1 and 2 connected to the battery selector switch because they connect to the bottom of the switch. So I unscrewed the panel it is mounted in and when I lifted it up, the battery selector switch came apart in pieces! The top of the switch was screwed to the panel but the bottom half of the switch was completely separated and several pieces fell out of it! The receptacles for all 4 of the screws that come up from the bottom were broken. I speculate whoever installed the switch used an impact driver and over torqued them. Then they failed over time.
I thought I needed to replace the switch, but decided to try to see if I could repair it first. I took everything apart and carried it into my shop. Once I had it laid out, it was pretty obvious how it was supposed to go back together. I lined everything up and super glued the base to the top and clamped it for a while. Then I re-installed everything, re-connected the batteries and tested it all. Everything works as it should.
The glue may not be a permanent fix. But the switch is readily available for about $45. I'll replace it if I have to.
