blown fuses
PaulaG
I have a 2006 bennington pontoon. I installed a trickle charger to the battery and in the process I accidently touched one alligator clamp to the other and sparks flew. Since then the panel on my dash is not working. The motor starts fine.There is a reset button beneath each rocker switch. They have no spring left when you push them in. My question is, are the fuses located in these reset buttons and if so, how do you remove? Is there a main fuse that goes to all the switches. I dont see a fuse panel. Please offer suggestions.
