BulldogsCadillac
Just some guy
Okay, so I'm in dream land again, trying to figure out what are good options to have and what is not. Feel free to give me any advice!! I don't want to break the bank with this as it will be an hour away from my home, so it won't be used as an everyday, mostly just for parking the boat and probably some junk my dad will pack in it!! So here is a general description of it. Tell me what needs to be changed.
* 30x45 with 16' walls
* I'm thinking a 20x14 overhead door on the 30' side
* It'll be tin roof/siding
* Standard stud building, engineered trusses
* In floor heat
* I was thinking of adding a u-drain (20ft or so) wife thinks this could be a waste and doesn't know why we would want it, here is a link, http://www.u-drain.ca/
* A 36" man door
* Insulated - just regular good enough?
* Now, would you do tin on the inside, or better to sheet it in plywood or drywall? what is the benefit of each?
* Electrical isn't included with the builder, so if he sheets in tin then I have to run conduit on the wall surface for everything. Is this a pain? More expensive?
* Should I do an overhang around the building, which then require soffit and fascia?
* Is a 5" concrete enough?
* 1 foot square rebar good?
* do you usually put the 1" Styrofoam under the concrete pad? If not, should I be?
I assume the builder guy knows what he likes to do, but I am just wanting to make sure what he wants to do, and what you guys tell me should be done, are the same thing!
Is there anything else I'm forgetting? Would it be stupid to say forget the big shop, and just build it like 15x45 so all that fits is my boat and a bit of storage on the side? Wonder what kind of cost difference it would be?
Thanks everyone!!
* In floor heat
* A 36" man door
Thanks everyone!!
