Captains Seat Adjustment Lever
Mike&Elaine
While driving boat, seat moved backward causing difficult steering. Tried to adjust seat position but lever arm came off completely. Found both plastic clamps that hold lever arm in position broken. Checked the other captains chair and found one clamp broken on the lever arm. Plastic clamps should not be used as they will not last very long. Tri-toon only 2 yrs old.
Pbakk
had the same problem with my 2019, only on co-captain chair. I doubt that it was used more than 4 or 5 times. Dealer replaced the entire seat base. Hopefully only a one-time item.
Baja 252
LOTO
Wow, the same thing broke on my seat this week. I figured it wasn't worth it to mess with the dealer. I just made one out of an old aluminum bracket I had. Works great.
