The Hillbilly Barge
- Messages
- 244
- Reaction score
- 296
Does simrad offer technical support for their products,seems going straight to the source for advice would be the best bet
Simrad and our dealer told us to change the angle of the transducer to find "clean" water so it is able to read better. Haven't had much luck yet but will keep trying.Does simrad offer technical support for their products,seems going straight to the source for advice would be the best bet
I think one of the first two listed on the 10th page - not sure which one but it has temp. Not any of the longer ones but thinking I might switch out to active -imaging.Does anyone know which Transducer they are getting with their Simrad: Active Imaging 3in1, Med/High HDI, TotalScan or a non-Simrad version (options per simrad)? Attached were the items I could find on the website, but no useful comparison / feature list. https://www.simrad-yachting.com/sim...alscan-skim-6ft-mh-455800-single-pk-053e2abd/
Hey BK - did you ever try flipping your anode around?Playing around with the angle of the transducer.....
I think you mentioned that last time. Thx for reminding me. This way the water would be "cleaner" when passing the transducer.Hey BK - did you ever try flipping your anode around?
yeah I'm pulling for you, I know this has been a big disappointment. I'm 99.999% convinced you'll get there with the right set up.I think you mentioned that last time. Thx for reminding me. This way the water would be "cleaner" when passing the transducer.
Good call - even at those speeds a sand or mud bar can come up quickly on you and before you know it your skeg is getting polished. I run pretty aggressive routes outside of channel markers to save fuel but I roll the dice when there are oddball variations on the river bottom. Depth data is only useful under certain conditions so you need the full suite - prior knowledge of the area, visual cues (variations in water color or surface action), nav charts etc.I think I'm going to just stay under 20 mph when I'm in unfamiliar waters.
Let us know how that works out. Looks promising.Just came across this and think I will give it a shot. The only problem is I can't test it for a while...hard water.
JR-3 Speed-Reeder Transducer Bracket - Johnny Ray, LLC
Introducing the New Johnny Ray Speed-Reeder Universal Transom-Mounted Transducer Bracket Would you drive your car without being able to see through the windshield? […]johnnyraysports.com
Ha! That was one of the multiple angles I tried........all with the same result! No matter where I put it it stopped reading about 18-20mph.Is that angle working for you? That looks pretty radical. Almost a forward facing sonar)
Truer words have not been spoken. I was limited on how far down I could move mine by the cable length available. Fortunately, what I did have was good enough to allow readings into the high 30s.This has great potential depending on how much “slack” is in the transducer cable.
My dealer received confirmation today that the Transducer included with the Simrad's is the lower end HDI, with no ability to upgrade without a full custom request which apparently they are not thrilled to accommodate these days, and could delay boat delivery (whooo - don't want that). The Active Imaging 3-1 apparently is a much better unit per every review I could find. The big issue with upgrading after the fact is the wiring - I am trying to find out if they each have the same # of wires (I think the 3-1 has an extra line to support the 2D imaging). Just not sure how they would be able to pull a new wire without a huge amount of work.I think one of the first two listed on the 10th page - not sure which one but it has temp. Not any of the longer ones but thinking I might switch out to active -imaging.
Sonar and Transducers | Simrad USA
