Designer Vinyl Floor Suds
Kermo75
Kentucky
We have had our boat for 4 days and have had it on the lake twice.  When water is on the floor and you walk, it suds up.  Is that normal because it is new?  It dries and I haven't noticed any staining.  Do you think we should rinse it with water?
Have never had that issues with my vinyl floor.   Sounds like you should give it a good rinsing to get whatever residue is on your floor from the factory.
Our Seagrass did that. It did goes away after a few rinses after the day on the water.
Nothing like that to report with our bamboo oat flooring. +1 on rinsing it down, but it might take several attempts to totally rid you of the problem. Nice Bennington you have there! Enjoy...
Our seagrass did sort of suds up a bit when it was brand new.  Now that it has gotten wet a few times while out swimming there hasn't been an issue again.  I'm guessing it's something in the manufacturing process of the seagrass (or designer vinyl in your case) that causes the suds.
We have that happen also, same floor.  I figure it will go away in time.
Same here, it took a few rinses with the hose and it went away.
Same thing happened with our Seagrass flooring.
