DIY RGB LED Cupholders
Jim_R
Another of my many second season upgrade projects was to use some of the SMD 5050 RGB LED strip 'left over' from my perimeter lighting project as interior accents. This DYI RGB cup holder idea is one of those uses.
In another thread on compartment lighting, I introduced the concept of cutting strips down into shorter segments, and soldering lead wire to form individual components. The SMD 5050 strips I have allow for cutting every three LEDs, or two inches, and have soldering pads for attaching the 4 lead wires - Red, Green, Blue and +12V (Black). Here is a two inch segment after cutting, splicing, and waterproofing with silicone.
My cupholders are plastic, not SS like most supplied by Bennington today, but these methods work with either.
To modify the cupholders, I had to remove them first. In my case this was much easier said than done. In the year my boat was made, Bennington wrapped the cupholders with what appears to be masking tape, and force fit them in the mounting holes. Some were relatively easy to remove, while others were difficult. The cupholders mounted in the rear L shaped seating group were the most difficult, as there was no access from underneath. I eventually crafted this "cupholder removal tool" which allowed me to apply enough leverage to remove them.
With the cupholders removed, I then drilled holes to align with the three leds - if like me, one has 10 cupholders to modify, creating a template helps a great deal.
Next I installed the LED strip over the cutout using silicone as an adhesive, and secured it in place with zip ties. The zip ties could probably be removed once the silicone dries, I am just leaving them in place.
Bennington usually supplies cupholders in pairs. Here are a pair of leds wired together using a European style electrical screw terminal block connector. These connectors typically come in 12 connector lengths and can be cut down, so I created multiple 4 connector blocks to facilitate wiring of the 4 connector RGB wire. I wired up the LEDs first, tested them, connected them together, tested them again, then mounted them to the cupholders.
I wired up the LEDs first, tested them, connected them together, tested them again, then mounted them to the cupholders. Doing it this way meant I had to install them to the cup holders, or at least the second cupholder, at the boat.
Like any 4 wire RGB LED strips, these require a controller for color changes, fades, brightness, etc. here's a pic of a couple installed.
Enjoy!
lakeliving
Looks great! I see all guys doing getting creative and making modifications to your toons and it get me thinking about ours. I know as soon as I walk out to the boat with a drill in my hand my wife would kill me. She likes things "stock" factory original...oh well.
SEMPERFI8387
York, Pa
That's freekin awesome looking ... gotta do this now...... :wacko:
WoodenPontoon
Jim-R - That looks really great! Not only is the idea of the DYI lighted cup holders sound interesting, but the step-by-step instructions and pictures are top notch!
LakeLiving - I go up unto my boat all the time with a drill, my wife almost expects that!!!!! LOL
Dan
lakeliving
Dan
As you have completely built your boat with your bare hands, I'm sure she has complete faith in you! Your craftsmanship is unsurpassed. If I walked on our boat with a drill I'd walk off with a black eye!! Just kidding! It would be hilarious to set up a hidden camera, get on the boat with a drill and see her expression as I pretend to drill on the helm. That would be priceless!
BulldogsCadillac
Just some guy
Dauphin, Manitoba
Not being a jerk, isn't it DIY? Do It Yourself? Just wondering if there is another term we're using. Sorry, really not being a jerk.
Oh, and they look awesome by the way!! It astounds me how handy and smart some of you people are!
BulldogsCadillac
Just some guy
Dauphin, Manitoba
PDX has another weekend project!!
Jim_R
Too funny - perhaps it should stand for Do it Yourself by Idiot. :p I even fudged the pic of my cupholder removal tool. I can't fix the title, but at least I was able to fix the pic.
cwag911
Fixed the title for ya Jim.
BulldogsCadillac
Just some guy
Dauphin, Manitoba
It didn't matter, like I said, I wasn't being a jerk,i was thinking maybe it was Doit Yourself Installation!
Jim_R
Derrick no worries, all in good fun.
