Drainage tubes on 2011 24SL1
ArtJ
Lake Oconee, Georgia
Console cup holders on 2011 24SL1 each have a drain hole with a plastic tube connected that drains below the deck. Center of console also has a depressed area with a drain hole, however, underneath the console there is a barbed hose fitting but no drain tube attached. Is it missing, was it spliced into one of the cup drain lines or does water just drain onto carpet under the console?
I’d say probably missing. Go to Lowes/Home depot. In the the plumbing section they have told of different size tubing. Buy enough to reach from cup holder to the harness boot that the others go to.
