all of my electrical accessories are out, I've changed all rocker switches and fuses but still nothing!! Also i have power coming to my guages and controls that are working. I don't know what else to look for..
Or the circuit breaker at the battery (that doesn't look like a circuit breaker). The gauges run off of power from the motor, so they would work even if accessories do not. Mine was pretty nasty looking and I had to do a search of the part number to figure out what it was.
Can you tell me what happened to your electrical issue. I am having the same problem. Last night everything worked. Today nothing on the panel except the guages. I did find that if I jiggled the cables running down the rabbit hole the guages would come on them go off. checked all connections and they are tight. checked the fuse and looks in good shape. Where can I have a loose connection??? such a mystery. Hate to take boat in for service. It is a huge hassle.
Any suggestions?
