Electrical cable caught in my prop
Gordon
Has anyone found that there main electrical cable at the motor is to long. Just got mine caught in the prop. This should not happen.
dannyleininger
Lake Wales Florida
Ouch, I can’t imagine how that could happen. How about some pictures.
dannyleininger
Lake Wales Florida
Amazing!
DaveyJ
Moorhead, MN
Leaving that much extra cable seems like the dealer made an error in rigging the motor. That’s not physically possible the way my boat was rigged.
Cumberland Ben
Lake Cumberland
I have a friend that this same thing happened to this past Monday. I had no idea there could be that much slack in those cables. Lucky I was with him to tow him in.
Mike31406
Never heard of that happening before but there is a first time for everything.
mowdoc
That is the main ambilocal harness from Yamaha to the dash. This harness IS NOT installed at Bennington factory but rather is a dealer mistake. If the rubber coating has any damage at all you need to request your dealer who rigged the boat to order and install a replacement harness. A lot of water will be in contact with this harness over the years and any violation of the protective coating is certain trouble in the future.
mowdoc
Yamaha makes these harness very long as they do not know what size boat it will be rigged to. The dealer who rigs the boat should coil the extra and tie it SECURELY out of the way. This is normally secured to below deck inside frame above a pontoon.
