engine height
mtudb24
Just curious as to what engine you have and what hole its mounted in:
2011 2275 RCW. 150 MERC OPTIMAX Pro xs. Top hole
Todd
2011 2250 GCW ESP 20 inch transom 150 yamaha 20 inch shaft. mounted as low as it can be.
2011 2275 RCW 25" transom 175 suzuki 25" lower unit mounted as deep as it can go ( top hole).
What kind of speed and rpm to you get at WOT. Also, what range do you usually cruise at.
I need to play with some different props as I currently am only getting around 3450 rpms and 35 mph gps speed with around 30-45 gallons of fuel 2 people and all gear and cooler. I usually cruise at around 25 mph at 4000-4200 rpms but that will probably change after I get the right prop on to get the wot rpms back up around 5800-5900 rpms. thinking I need to be in the 13 x19 range but am dealing with some local folks with props to let me borrow a few different ones to get it dialed in best.
Thanks
I am 1 hole up from all the way down. Seems perfect, however I get a bit of ventilation with loaded with 12 people and running low 30's.
2574GLi with ESP, Merc 250 Pro Verado, 15" Enertia prop, 6500 rpm at 46 mph with 4 adults. Boat is new and I think I need to go up to a 17" prop.
