Evinrude 150 HO
tbabcock28
I have a 2019 SX23 Tritoon with 150 HO Evinrude , can anyone tell me the proper hole location for motor mount, It came from dealer mounted in the highest possible location and sits deep into water.I can only get 5200 rpm wot. Around 39 mph with two on board.
DejaWiz
Nebraska
What size and pitch prop are you running?
Only getting 5200 RPM with the throttle pegged is usually the result of an incorrectly sized/pitched prop.
Jack M
Indian River ,Michigan
How many hours do you have on the motor ? There is a 15 hr break in chip that will burn out . I had a lot fluctuation in RPM's at the 10 to 15 hr point
DejaWiz
Nebraska
I think its the Rebel model prop that came installed when purchased boat new.
Any markings on it, such as 15.5 x 17 to designate the diameter and pitch?
David G
39 MPH is probably all a 23' will do with 150 HP.
My 22' Did 41 w/ 175 HP.
