Hello, I have a 2013 Bennington Q25 with 21 hours. I bought new and the day I got it, a "OBD service soon" notification was on my gauge. The dealer told me that it would eventually reset after an hour of so on the water. Fast forward to today and I have been having some real complications with the boat.
I have 4 notifications including 4 fault codes: Fault Codes: 17,31,33 & 71. 3 of these codes deal with Engine Sensor not operation property and or Oxygen Sensor not operating properly, the other fault code indicates a Miss Fire.
I replaced the O2 Sensor (4) as per the P0130 fault code and per a Authorized Mercruiser mechanic suggestion and the boat now starts up and runs like a sewing machine. But after 10-12 minutes, I get an alarm followed by erratic RPM and loss of about 50% power. If I put the boat back to neutral and wait about 10 seconds, I can then increase power.
Any one know of this problem? I have talked to about 3 mechanics and they all suggest I pull the boat out of the water but none of them seem to know anything other than- "you need to bring it in so I can see it". Anyway I can clear my fault codes or should I re-replace all the O2 sensors with new ones?
