Installed a front SureShade Power Pontoon Bimini Top on my 2021 22RTFB (https://store.lci1.com/sureshade-power-bimini-power-bimini.html), with rear factory powered bimini already installed. Mounted the bimini facing forward. Some pictures on the web have it mounted backwards that has the bimini in the arch position slanting to the bow of the boat. I think mounting in normally with the arch slanting aft, like the rear bimini (see pictures) looks better. Also installed the 36" support arms to support the bimini when in the arch position (https://store.lci1.com/sureshade-sport-arms-for-power-bimini-36in-silver-2020134627.html). Install fairly easy. Routing the wires through the railing and into the helm was the most time consuming. Spliced the positive and negative leads into the same wire that powers the rear bimini. The kit comes with a remote and a wireless controller which mounts under the helm. The controller also has a small toggle switch that controls the Bimini should the remote fail. Next projects will be to add front straps for higher speeds (20 mph max speed without front straps), and to replace one of the spare switches on the helm with a 3 position switch to control the bimini. Very pleased with the results.
