Fuel Additive
Jim & Mikki
Sebastian, FL
We will be getting our first Bennington 2275GCW delivered later this summer and I don't know which way to go with fuel. Corn free or E-10 with some type of additive. Does anyone have information on what would be the best additive to use with Ethanol? Thanks
I like the Mercury Quickare product, I use it on with every fill up and use Quickleen on every other (I have a 150hp Verado engine):
From the Merc. parts express website:
Quickare is a fuel treatment that can be used at every fill-up to: * Maximize engine performance with all grades of gasoline * Help control corrosion, gum and varnish build-up and phase separation associated with ethanol-blended fuel * Help control moisture and corrosion problems associated with non-ethanol-blended fuel * Clean up existing varnish and gum deposits from fuel llines, tanks, carburetors and injectors, intake valves and spark plugs * Keep fuel fresh between fill-ups - up to 3 months * 1 ounce treats 10 gallons - 12 ounce bottle treats 120 gallons
I have used Valvtect Ethanol gas treatment and also the Marine formula Sta bil. They are both very good products. But since our marina has ethanol free fuel I stopped using them............
These fuel additives will still help keep your fuel system clean and guard against moisture and corrosion. Unfortunately fuel doesn't stay long in our tank..............Ha!
I just remembered............I have also used Star Brite star tron gasoline additive. Good product, inexpensive, and treated many gallons.............
