Roland
Hello guys... I have one of those " what would you do questions". Of course this all centers around gas and ethanol. Finding ethanol free fuel around here is getting harder and harder to do.. I have 3 options.... what say you?
option 1.... I have located a station about 45 minutes from my home that sells ethanol free fuel in all 3 grades, 87, 89 and 93... however as far as the manufacturer, it's simply called "unbranded ".. I have no idea if that means it's a substandard fuel with little or no additives or what? Just don't know.. I only use 2 or 3 tanks a season so while driving 45 minutes each way may not be my favorite thing to do, it's still better than buying ethanol tainted fuel.. but I worry about the unbranded thing.
Option 2. Much closer to home, there is a Citgo station about 30 minutes from me that sells ethanol free fuel, but only in their 93 octane... concerns here: first I read somewhere that I shouldn't burn 93 in my motor simply because it burns hotter and could lead to more carbon build up, also, from what I've read Citgo is not "considered" an upper tier fuel.. should that be a concern of mine...
Option 3.. just go down the street like I always have and buy either texaco / shell / big name brand gas that is 10% ethanol and treat it with stabil marine or startron.
2 other question, I'm not mechanically inclined, but can you change out fuel lines if the toon has a full tank of gas? and what grade of fuel do you run in your boats.. owners manual says "no less" than 86, but I've read that if fuel sits awhile it loses a point or two in octane so it might be advisable to go with either 89 or so..btw, my motor is a yamaha 75 4 stroke. I know it's a lot of questions, but I thought it would be best to bug you all at once instead of coming back with question after question for several days... thanks in advance for you input...
Roland
Roland
