Hour Meter ?
Maerick
I have a 2009 2250 GL with only a tach and no speedo. It has what looks like an hour meter on the bottom, but it say A6005.2 . Surely it would have 6000 hours . I was told the motor had 285 hours on it. An ideas ?
A mechanic should be able to hook to it with a meter and read the hours. I've seen it where they can tell you the percentages of those hours where the engine was run at different RPMs. Your engine should be new enough to have that port and the mechanic shouldn't charge much or charge anything if they're doing any other kind of work.
