livewell operation
iToon
Maybe my 22Sfi is missing something, I read the manual and it never gave a full description of using the livewells, I was on the lake just now and filled one up(the other is leaking on the battery), BUT, now its full where do you drain it? I cannot find a drain plug and everything looks solid. Thanks for any help.
Bennington Newby
iToon
Friar
My livewell has an overflow tube installed over a hole through the base and the deck. When I need to drain, just unscrew the tube from the base and water flows out the hole.
iToon
Thanks, figured it out after your post, I also found my leaking well was due to a cracked receptacle for that tube. The dealer is fixing it for me.
