Looking for Blown fuse
Bob Robinson
I have a 2013 18 Foot Bennington and all of a sudden about a month ago I started it up after not using it for a month or so and the radio, lights and horn will not work. Everything else is working fine I can't find a blown fuse or anything under the dash, it's on a lift so I hate to take it off and take to a dealer for repair. Bob Robinson Estero Florida.
Have you checked the breaker on the helm ? Also check the connection on the switch under the helm .
My depth finder stopped working - tracked it down to a bracket under the helm that had fallen off and pulled the wire to the rocker switch with it. Plugged it back in and everything worked. New bracket on order under warranty.
If above is checking out, check connections for corrosion. That can creep into the situation sometimes and may need to get cleaned up.
