Rssuttle
- Messages
- 78
- Reaction score
- 36
Someone on this site has a formula on how to fine tune a prop.
Looking for prop diameter and pitch that can add to my current prop
21’ Bennington SSX pontoon with no added packages or under shield or lifting stakes.
2020 Yamaha f115 four stroke
Gear ratio 2.15:1
Rpm range 5300-6300 want to be 5900-6000 wot Yamaha says 5500 is when the 115 horse power.
Pontoon Weight 2,300lb + motor 377 lb + 2 people 500lb which includes other things I’ve added. Rod reels cooler etc. Total 3,100lb and 16 gallons gas.
Yamaha k aluminum prop came on it 13.5 x 15 running 5800 rpm’s 26 mph. Prop Has no cupping or rake just simple straight prop. If I add 3 people still at 5800 rpm 22 mph
Bought 2 props from turning point and these have some cup added to make it more aggressive for top speed and hole shot.
. 13.75 x 15 5100 rpm’s 27mph
Add 3 more people 5000 rpm’s
23 mph
14 x 13 6300 rpm’s 24 mph add 3 people 21 mph Eats Gas.
I’d like to stay with aluminum because I don’t have any thing to compare one too
My thinking is to take the 13.75 x 15 and change the diameter to 13.25 or 13. Should Bring rpms up 300-500 or roughly 5600 rpm. I could lower the pitch to 14 but probably loose mph but not sure
The 14 x 13 if I change it to 14x14 and be 5900-6000 rpm’s.
I know the boat has two toons I know but I feel like I could get more.
If I have to I’ll go to a ss but I’d be starting over.
I’ve looked through all the Yamaha Bullintens but can’t get one close enough to compare.
I know this is long. Maybe I’m chasing a rainbow. And No I can’t go buy a 150. Lol
Really hoping someone can use there math skills and help out.
Gear ratio 2.15:1
23 mph
