Michiman
For those of you with the Mercury smartcraft gauges, I'm hoping you can share your experience with regard to the "tilt" meter. Leaving the dock on my maiden voyage, I thought I was trimmed all the way down because the trim read "0". However, when I went to take off the bow went up quite high and the prop started to ventilate. I stopped and trimmed it down more, much to my surprise!
My first assumption was that the trim gauge didn't work but later when I was trimming it all the way up it did move from "0" well up past "9". However, the engine moves a great deal while in the "0" range, which I am not at all used to. With my prior boat, if the engine was going up or down, so did the gauge needle.
Question: Does your "0" have substantial engine movement before it reaches "1"? Again, if I'm on the high end of "0" I can't even take off. I have to continue to trim down to the low end of "0". Not good in my opinion.
