DiamondDave952
- Messages
- 126
- Reaction score
- 151
I am perplexed as to why my new Yamaha F115 LB was not peeing when I attached the muffs to the water intake with the water turned on full blast (Full blast being what my well pump is able to deliver) so that I am able to winterize the motor. I was able to submerge the motor in a plastic garbage can to simulate the motor being in the lake since that was the last know condition that the motor worked properly. Doing so, I was able to get the motor to pee. See picture below. Feeling relieved that I my motor was working properly; I am now wondering why the motor did not pee with the muffs attached. For reference, water was spraying out between the muffs and motor housing as well as the other orfice on the motor. Is there a minimum water pressure that is needed? Anyone else experienced this before? Thanks for any insights you may have.
