Port Side LED & Underwater lights working intermittently
bankerii
Since delivery, the port side LED and underwater lights on my boat have worked intermittently.   Sometimes they come on, sometimes they don't.  Never had a problem with the starboard side.   I'm sure it's just loose connection somewhere.  I don't have a trailer and nearest dealer is a couple hours away.  I would like to try to troublshoot myself.
Anybody have recommendations on what I should be looking for?  Not sure how or where the wiring is run.  My boat is 2275RCW.
Thanks!!
First, look in the technical section for your wiring diagram, and familiarize yourself with the circuit you are troubleshooting.
Then, start looking for loose connections, particularly the ground wires, most intermittent problems are from  bad ground connections.
Use a 12v test light to check the positive side if all grounds are found to be intact.
It should be a simple fix, let us know what you find!
Call your dealer .
I had a bad "connector "on my anchor light
