Prop Help
mbhenry1955
Cincinnati, Ohio
Looking for any experience with prop selection.
I have a Benny 2250 with the Honda 250.
Hoping to find another member with the same or close setup to get prop suggestions.
Thanks
A 17 or 18p Enertia should do the trick, I run a 15p Enertia with our 150 and it's great. Have you had the boat out yet? If so, what are your numbes?
No numbers to post yet, as we've not had it out yet.
Still in shrink wrap from the factory.
Can't wait till spring.
My dealer said the the Enertia is the prop to go with, but he wants to try different pitches to dial it in.
I'm looking for a good starting point.
The pitch may be different with my Honda 250!
18p Enertia was perfect for my 2275RCW and Verado 250 Pro. You should be close with 17 or 18.
Member "Gerry" is fairly close to you and has a 2575 with Honda 225 and 16p Enertia.
