ronfl
OK I realize prop questions are asked here many, many, many times but I am very new to Mercury am in need of assistance. I just purchased a 2010 2550 with a mercury 150 optimax. It has a quicksilver prop and it measures 8" from center of nut to outside of prop fin and it says its a 2008P15 so I assume it's a 16" with 15 pitch. Not sure what the 2008 is? Toon is a double with 25" and lifting strakes and under deck shield. Test drove the boat on smooth water with 4 adults and 1/2 tank of gas. Really smooth and handles the toon well. Issue is the max RPM was around 4800. I believe this motor should be in the 5400 RPM range at top end? If so would 4 adults take that many RPM away or is the motor over propped? Any suggestions or advice.
