I am getting a 24LSB with a Yamaha 250HP VMAX with SPS plus. Should I be looking for a specific prop or go with what comes on it ? - Dealer will place what Bennington recommends but I don't know what that isReliance SDS 14.5x15 is the usual go-to prop for any of the Yamaha 2.8L engines.
I am getting a 24LSB with a Yamaha 250HP VMAX with SPS plus. Should I be looking for a specific prop or go with what comes on it ? - Dealer will place what Bennington recommends but I don't know what that is![]()
Hope your dealer comes through, but might be worth asking now what make and model he intends to install instead of being disappointed come delivery time. My dealer put the completely wrong prop on the boat and claimed that top-speed was within spec. While top speed was adequate, it had terrible efficiency and took forever to get on plane. After datalogging to prove my case, it took a while for the dealer to source a substitute prop but that was even off the mark. I finally reached out to Ken at Prop Gods and ordered my own, and the dealer still owes me a prop (spare at this point). That was almost 1 year ago.I am getting a 24LSB with a Yamaha 250HP VMAX with SPS plus. Should I be looking for a specific prop or go with what comes on it ? - Dealer will place what Bennington recommends but I don't know what that is![]()
Why would you need it? I was under the impression you would want this if jacking up the motor to run skinny, but pontoons usually aren't running this shallow. I run in some tight areas probably 18-22" and even tilting the motor up I can get enough water to the pickup. I would be more worried about sucking in a bunch of mud/sand and prematurely killing my impeller.Also, is a low water nosecone needed or a good idea?
For an I4 motor I think you'll hear most people recommend a Reliance prop to reduce prop chatter at low RPM. It's more expensive but for an extra $200??? you have many hours of much more comfortable boating.
From what I read the Saturn will be ok performance wise.
Yamaha Saltwater II 15.75x15 (part# 6CE-45976-20-00) is what the dealer is putting on my boat.Just checked the Yamaha Performance Bulletins for Pontoon rigged with the VF250, and it seems the most common prop is the Yamaha Saltwater II 15.75x15 (part# 6CE-45976-20-00). Top speed in the 43-46 MPH range, mostly.
Alternate options are the same Saltwater II series, but in 15.5x16 flavor (part# 6CE-45938-20-00) or 15.5x17 flavor (part# 6CE-45978-20-00).
There are a handful of entries in the YPB's for these two, and appears top speeds are in the 46-50 MPH range for either one.
Good starting point - probably better to be a little under-propped than over. You'll probably have a little room to go to 16p as Dejawiz mentioned.Yamaha Saltwater II 15.75x15 (part# 6CE-45976-20-00) is what the dealer is putting on my boat.
