Replacement depth gauge transducer and fuel tank sending unit 2004 2575RL Tritoon 305 Mercruiser Alpha One
paladin707
What brand of gauges did Bennington use in 2004 ?? I want / need to replace the transducer for my depth gauge, it got knocked off long ago. The fuel gauge quit working recently and the repair place wanted to cut a whole in the floor to access it...this did not sound correct...I figured the panel between the fuel tank and engine bay could be removed to allow access ..... any thoughts ???
BigKahuna
North Carolina
I had a 2004 Bennington 2275 RL I/O 4.3L V6. The engine and the gas tank was in the motor pod/center tube. Easy access to both. Also I found a complete matching set of original gauges for our Bennington at greatlakesskipper.com. They specialize in hard to find parts/accessories for older boats.
paladin707
Greetings and thank you for your reply, did the gauge set come with the transducer to mount on the back of the port pontoon because that is the piece I need??? any idea of the brand of gauges??
BigKahuna
North Carolina
That's a negative. The transducer didn't come with the gauges. Also it was the original gauges from 2004, our model year. I'm sorry I don't know the brand that Bennington used back then......
