Seagrass flooring and 303
JBL
Clayton NC
Which 303 product do you use on seagrass carpet?  I know it is a vinyl. bit not sure if I should use the fabric protectant or the regular vinyl product.
Dont use it on the vinyl floor ,too slick .
I have carpet so ,I have no recommendation for Sea grass
I have a copy of the maintenance and clearing instruction for the seagrass covering. If I knew how to down load it I would send it to you. I got it from my dealer so may be you can check with your dealer. Anyway the only thing to use on the seagrass is a mid soap like Dawn to clean the floor or if you get something on the floor like tomato sauce, Betadine. Mix a 1:10 bleach to the mild detergent solution. i would not put any type of wax on the seagrass it will become very slippery.
KISS simple green
Thanks Sanity3, I will check with the dealer for more info.  I still need to go thru the packet of new owner stuff I got.  I washed the boat after riding and the water ran off the seagrass quickly.  Seems to be really low maintenance.
