MikeOnTheLake
The bracket where my stern light mounts to the bimini top has teeth where the pole swivels on the bracket to hold the pole in place. However, those teeth do not lock into anything and just press against a smooth surface (pictures attached). Should there be another piece on this bracket for the teeth to lock into so the pole stays in whatever position you want it? Right now I need to tighten the screw as much as I can to keep the pole from moving, but it still moves from vibration when underway.
I've found the Perko replacement bracket and can buy it from a number of different places, but none of them on-line show a clear picture of the teeth and if they lock into anything.
Thanks,
Mike
Thanks,
Mike
