Kahlua0517
The tach on my three week old boat sporadically stops working. It will stop at zero some times or 7000 RPM other times. Any known problems with these things?
Double check the connections. Sounds like loose connection.The tach on my three week old boat sporadically stops working. It will stop at zero some times or 7000 RPM other times. Any known problems with these things?
That was my initial thought so I took a peak under the helm console but didn't find anything loose. I guess that it could be back at the engine.Double check the connections. Sounds like loose connection.
