Tachometer Reading
Je1279
: Rotterdam, NY
When the boat is off the tach is reading 1,000 RPMs. Is this normal? It has a Yamaha 115 if that matters. If it's not normal, is there a way to reset it to 0? Thanks In advance!
Normal, mine does the same.  When you start it it resumes accurate reading.
Yep, mine does the same.
Mine is also the same
I noticed the same thing this past weekend. I pulled in a cove, turned the engine off and dropped anchor. As I went back past the helm I noticed the tachometer. I actually turned the key again to make sure it was off since the engine is so quite.
