TB price check on extended aft deck
SEMPERFI8387
York, Pa
TB,
Could you verify MSRP price on following, I know you are still working on some pricing, but need to verify.
On a 24SLX extended aft deck standard vs. heavy duty rub rail option adds $18 LIST ($913 to $931)
On a 24GL the same option adds $90 ($913 to $1003)
Is there that much difference in material on the GL ?
ALSO: Can you just get the standard SIDE heavy duty rub rail WITH Extended Aft Deck, or MUST you use the HDRR option on extended deck ?
Thanks,
Smitty
This is a trouble area on BYB; we'll be working on it next week along with a couple other tricky spots. If you order an extended aft deck with the HHRR (heavy duty rub rail) or the SSRR (stainless rub rail) you need to select the corresponding aft deck, since the insert for the rub rails is different. TB thinks the price you are seeing is the difference in the insert price...not the complete cost of the options, which should be listed elsewhere on the options checklist.
