Is it normal for water to get in? Yes, it can happen from rain etc. Should the water stay in there? No, there should be a bilge pump to drain it out. Check your switches for one or if unlabeled or unsure, get into the locker and check in the lowest spot.
Welcome ! Turn on your battery switch ,then try one switch at a time.The pump will make a noise if there is one. Like Remediation said look in the toon for the pump!
