kaydano
- Messages
- 4,287
- Reaction score
- 2,164
I brought the boat back to the house, and my Mercury 115 started up instantly on the first start of the season. I had muffs on the water intake and had the water turned on plenty. No water came out the pee hole, so I immediately shut it off. I probably had it running for just a couple seconds before I turned it off.
I then hooked up the hose to the flushing system. This is a fitting just above the pee hole, and the garden hose screws directly into this fitting. In the manual, it says to use this fitting after running in salt or muddy water. It says to run the engine at least 5 minutes so the thermostat opens and water can circulate through all the passages. Again, after starting the engine (hose hooked up, water on) no water came out the pee hole, so I shut it down quickly. Motor only ran maybe 2 seconds.
Do I have a problem, or am I just not giving it enough time to "pee"?
Both ways, no water came out. But, I only ran the motor a couple seconds each way, so thinking I may not have given it enough time.
Anyone know if there's a delay (longer than 2-3 seconds) before water comes out the pee hole?
