hi I have a 2012 2275 RCW tritoon with elliptical center toon with strakes and a f250 Yamaha. Just got back from a trip to Powell and could only get 5000 rpm wot and 35mph the elevation is about 3400 ft above sea level. This is with a power tech ele4r17pms275. With the same prop it would run a strong 45mph at 1500 ft above sea level with wot at somewhere around 6000 rpm. Lake Powell will be the lowest I will be running and around 7500 ft the highest. I would like a prop or props for top speed and fuel Econ.Thanks in advance
