What type of connector is this?
Jessb103
Can anyone share what this connector should be used for? It’s located on the front right side, right under my navigation lights. It has two of the exact same connector. I’m looking to add LED strip down the side and was hoping to find my 2018 Bennington SSRX came pre-wired. Thanks in advance!
Yup, spade connector, typically for the horn.
Thanks to you both. My factory horn is connected and working, so shouldn’t need to hook it into these. Does that mean I could possibly use this connection to power my LED lights?
Hold a multimeter on it and have someone flip all the switches at the helm. If there is power from one of the switches, hook up your led lights. I’ve found they put power to nearly all of my switches even though they don’t power anything. There are more connectors under the console that aren’t used on my unit. The manufacturer uses a standard wire bundle and each unit has different features.
